Thread: Illustrator cs3
    rande is offline Senior Member
    192
    Default Illustrator cs3
    We're working a large file that keeps closing the app. and submitts a report.
    50mb
    linked files
    PDF comes out 153mb
    anyone have any ideas to throw out.
    We looked for prefs to dump; couldn't find where to do that.
    thanks
    rande
    disbellj is offline Senior Member
    615
    Default Re: Illustrator cs3
    Is it PDF/X-1a joboptions from Adobe that you used?
    Don
    Soilworker is offline Member
    33
    I've seen this happen before. It's really frustrating.... the more images you have linked the more frustrating it can be. When I've encountered this it's typically because one or more of the placed images have corrupted.
    The best way to see if this is case is to grab all of the linked files and move them so that Illy doesn't know where to look for them. If the file opens fine (other than the missing images) then you know it's the problem. If it +is+ the problem you can try opening all of the linked images b/c in my experience the problem image(s) will often cause the native app to crash as well. Or, you can reintroduce controlled groups of the linked graphics so that Illy can find them again.... then you just widdle away the same way until you find the one causing the issue. If you're lucky you can hide that one linked file and tell Illy to extract it when it tells you it can't find it. Sometimes it can recreate a usable version for you. Otherwise you better hope you have another version somewhere.....
    Hope this helps.
    ~Soilworker
    33
    .... Oh, and if you wanted to dump your prefs just run a search on .plist files... find the Illy ones, trash 'em and reopen. It doesn't sound like that's the problem, though.
  1. Ink Coverage in Illustrator
    By Jiggy in forum Adobe
    Last Post: 08-04-2008, 02:29 PM
  2. Illustrator & DWG/DXF
    By svharter in forum Adobe
    Last Post: 07-16-2008, 03:44 PM
  3. XML in Quark or Illustrator
    By HiTech_Monkeyboy in forum Prepress and Workflow Discussion
    Last Post: 05-13-2008, 04:24 PM
  4. Setting Up Illustrator CS3
    By billw@mlode.com in forum Adobe
    Last Post: 01-30-2008, 01:28 PM
  5. Illustrator 10 pallets
    By almaink in forum Adobe
    Last Post: 01-15-2008, 08:34 AM
