Results 1 to 10 of 16
    31
    Default InDesign Page Information - slug line
    When printing a document that is smaller than about 4.75" (120mm), I find that the slug line drops off the media and pushes the page off-center. Does anyone have experience with this - or a way to fix/avoid it?
    Example: a 4.5x6" ID doc. - media/page setup 5.5x8" - Bleed and Slug from Doc. Setup, T&B 1", L&R .5" - Include Slug Area is checked in Marks and Bleed section of print dialog. Thanks for any insight/comments you may have.
    -Dan
    GinSu's Avatar
    GinSu is offline Senior Member
    126
    Default Re: InDesign Page Information - slug line
    I think if you actually have a slug in your layout with page number, filename and color information, you can turn off Page Information in the "Marks" of the Print dialog. It happens to us all the time and can make imposition a problem because the trim area is not centered and turning off Page Information is how we get around it.
    MC_JerryD is offline Junior Member
    26
    What version of Creative Suites are you using? I know this was an issue with CS2 but thought it was corrected in CS3.
    GinSu's Avatar
    126
    Nope, it still shifts off center if Page Information is checked in CS3.
    31
    Currently using CS3 but saw the same behavior in CS2.
    So it's not just me then. . .
    I did a quick search around Adobe's website and didn't find it listed as a problem. Will keep looking, thanks for the replies.
    -Dan
    26
    What imposition software are you using? We are using Preps.
    Whitaker is offline Member
    Dec 2007
    65
    We have the same problem too. It's a pain because we like to see the job name and page number on all our lasers of each page. The problem seems to be inconsistent. Some pages will come out centered up and down and some not. The larger the page the less likely you are to notice a slight shift in the impo. It's defiantly a bug, because I select "centered" for the page position in the print dialog box and the page doesn't alway come out centered.
    Des Moines, IA
    403
    This is a confirmed issue that I reported during the Beta testing of InDesign CS3. Unfortunately it was too late to get fixed for release. Hopefully it will get fixed in the next release of InDesign.
    If you want to make sure you get your word in about this and so it goes higher on the list of fixes. Then submit your bug report on this web page. http://www.adobe.com/cfusion/mmform/...orm&product=68
    By the way, the exact size when the Page Information marks slide is 334pt (4.638 inches). If your document is 335pt then the Page Information is fine.
    Dec 2007
    60
    Note that in the document set up dialog the slug area has four input fields. By making the value for oposite sides equal, the slug area can be set symetrically arround the page. At an appropriate size this will create a bounding box that encompasses the page information, and the page will be centered in that bounding box, and all will be well with Preps.
    31
    Thanks for the info, I'll let them hear it! And in the meantime - work around it.
    -Dan
  1. Emdash at the end of line in Indesign CS3
    By sivakumarr in forum Adobe
    Last Post: 06-17-2008, 09:34 AM
  2. InDesign exporting issues with slug area
    By ginaadams in forum Adobe
    Last Post: 05-20-2008, 08:28 PM
  3. InDesign line tool problem
    By John M. Morgan in forum Adobe
    Last Post: 05-13-2008, 01:21 PM
  4. Slug Line usage
    By Tech in forum Prepress and Workflow Discussion
    Last Post: 02-26-2008, 10:22 AM
  5. Replies: 16
    Last Post: 09-14-2007, 11:51 AM
