Results 1 to 5 of 5
    nickyg is offline Member
    50
    Default Acrobat 8 Pro - Preflight
    Hi Forum,
    Having some strange issues when preflighting PDFX files in Acrobat 8 pro, basically i have an additional check that verifies if keylines are below 0.25pt, when this check is run it errors on keylines that are 0.6pt ! and registration marks set at 0.25pt !...which is obviously wrong.
    Now i can lower the keyline check limit to 0.24pt to get around the registration issues, but i what about the incorrect error as reported below:
    Page 12: stroked 0.6pt CMYK (0.0/0.0/0.0/0.992) overprint on
    When i run the same check in Acrobat Pro 7, it passes ok...
    Can anyone help ?
    Thank you,
    Nick.
    Tech's Avatar
    Tech is offline Senior Member
    338
    Default Re: Acrobat 8 Pro - Preflight
    Hi Nick,
    I only use preflight reports as a general guide. Whatever it flags as wrong, I review it and decide myself whether the file is fine or not.
    One major flaw I see with all the talks about automatic work flow is, assuming software/hardware are error-free or at least better than human.
    50
    Hi Happy Friday,
    Thanks for your reply, yes of course human intervention is always needed to decipher any technical issue, however, i would like to know why Acrobat 8 pro is behaving this way....
    Nick.
    33
    Nick,
    can you please provide me with your preflight profile and the PDF in question.
    p.kleinheider [at] callassoftware [dot] com
    Please also tell me which version of Preflight you are using - "Show detailed view...." option - open "Preflight Information" triangle - read preflight version
    Regards,
    Peter
    735
    What happens if you try these two separate tests:
    1. Page 12: stroked 0.6pt CMYK (0.0/0.0/0.0/1.0) overprint on?
    2. Page 12: stroked 0.6pt CMYK (0.0/0.0/0.0/0.992) overprint off?
  1. Using Acrobat Preflight
    By billw@mlode.com in forum Adobe
    Last Post: 09-04-2008, 02:52 AM
  2. Acrobat 8.1.2 (Mac) Preflight
    Last Post: 07-29-2008, 10:34 PM
  3. Acrobat Preflight
    By sgravel in forum Adobe
    Last Post: 01-24-2008, 06:08 AM
  4. Replies: 0
    Last Post: 01-23-2008, 09:19 AM
  5. Preflight files
    By stargate in forum Prepress and Workflow Discussion
    Last Post: 10-12-2007, 10:20 AM
