    T-Rex is offline Junior Member
    Nov 2007
    3
    Default Fiery RIP for IKON printer and rotated InDesign Spreads
    Does anyone know about any issues with the IKON Fiery color copier drivers and any incompatibility with InDesign CS3 on a Macintosh using Leopard (OS X 10.5.4)?
    I am having weird things happening with printing spreads to our IKON CPP650 printer. It is equipped with the latest Fiery Command Workstation 4 and a Fiery Pro80 RIP.
    When I print out of InDesign a set of spreads, the first spread is fine, but the subsequent spreads will be rotated 90 degrees.
    Printing the files as PDFs out of Adobe Acrobat Professional works just fine.
    Any ideas?
    Thanks!
    rcreveli is offline Member
    Apr 2008
    71
    I figure I should reserect this thread since I am having the same problem. This happens with all Fiery's. We had two Canon, 2 Xerox and one KM and all have exhibited the issue.
    Savage is offline Junior Member
    Dec 2008
    23
    I had the same problem a few moths ago with a Fiery attached to a Xerox printer. I'm on a Mac, and the runaround, at the time, was replacing the Mac specific PPD with the windows PPD. A few weeks later, Fiery (or Xerox, not really sure) released an update that fixed it, and i´m now back to the Mac ppd... So, my advice is you guys try the other platform PPD, and/or check if there are any uptades available to the Fiery software (i used the auto-updater).
    Good luck!
    Apr 2008
    71
    Also,
    Check out this link on adobe's site it fixed a few other issues. Not sure about the roation yet since that is a bit random.
    Unexpected scaling and/or rotation when printing from Illustrator CS3 or InDesign CS3 (Mac OS X 10.5.5)
  1. Ikon CPP 550 printing negative image
    By Green Printer in forum Digital Printing Discussion
    Last Post: 03-04-2009, 11:51 AM
  2. Fiery S300 50C-K (Check power and cable connection) New printer?
    By JeffreyO in forum Prepress and Workflow Discussion
    Last Post: 07-14-2008, 06:01 PM
  3. Illustrator CS2 - thin lines appearing in image when rotated
    By Repro_is_still_alive in forum Adobe
    Last Post: 02-14-2008, 08:30 AM
  4. Lawsuits on Ikon Konica/Minolta CPP500 or C500 Internal Fiery or 8050?
    By k_graham in forum Digital Printing Discussion
    Last Post: 01-24-2008, 02:02 PM
  5. Replies: 0
    Last Post: 12-07-2007, 03:40 PM
