Results 1 to 7 of 7
    Bansheei is offline Member
    Sep 2008
    50
    Default Adding custom PPD's to Acrobat Pro
    Hi there guys,
    Adding custom PPD's in Layout programs is a common thing eg. Indesign etc...
    But is it possible to load a PPD into Acrobat Pro.
    We are using a postscript/OPI workflow and have a workflow specific PPD that we must use for postscript creation... But most of the files we receive are PDF's.
    I want to open the supplied Pdfs in Acrobat and then save as postscript using the workflows PPD.
    Does anyone know if this is possible and how to do it (where do you load it into the system/acrobat)?
    WharfRat is offline Senior Member
    189
    MAC - ?
    Should be the same as any other PPD
    Startup Hard Drive/Library/Printers/PPDs/Contents/Resources/en.lproj
    MSD
    443
    Not in a modern PDF-based workflow it isn't...
    It is NOT possible. When Acrobat generates Postscript, it does so in a device-independent manner (since the PDF itself is device-independent) and therefore has no need for a PPD.
    Leonard
    189
    You can't "Save As" PostScript from Acrobat
    and select any PPD desired?
    I have used workflows where the "experts"
    claim you must use their specific proprietary PPD
    for the RIP.
    This was years ago - and I found the claim to be untrue, anyway.
    But ... that is another argument.
    MSD
    Dov Isaacs's Avatar
    157
    Quote Originally Posted by WharfRat View Post
    for the RIP.
    MSD
    Actually, when Acrobat prints to a PostScript printer (as opposed to saving what is supposed to be a device-independent PostScript file), it does so based on the contents of the PPD file. Thus, if you have a driver instance setup based on a particular PPD file, Acrobat will generate the appropriate PostScript for that device based on language level and physical device capabilities stored in the PPD file. But defiinitions of such PostScript printer driver instances is not Acrobat-specific, but rather printer specific.
    633
    Dov,
    I wonder what you mean that definitions of such PostScript printer driver instances are OS-specific. I often use the ssicolor ppd supplied with Preps by Scenic Soft. Using it I am able to generate device independent separations where the built in Adobe Device Independent ppd does not permit it, and it works in both OS 9 and OS X. I believe this ppd works equally well in all versions of Windows.
    Am I way off base here?
    Dov Isaacs's Avatar
    157
    Sorry, meant printer-specific and have updated message.
