Reply
  #1 (permalink)
Old 07-02-2009, 10:48 AM
Colorblind's Avatar
Senior Member
Default Profile conversion within Illustrator?
I know you can assign profiles in Illustrator but I was wondering if there is a way to do a profile conversion in Illustrator (such as in Photoshop) once the file is opened. One workaround would be to save as PDF and do the profile conversion in the "Output" pane. So is there a "Convert to profile" command in Illustrator? I'm using CS4. Thanks.
__________________
  #2 (permalink)
Old 07-02-2009, 11:21 PM
Senior Member
Assuming you want to convert CMYK to CMYK, you could make sure the source profile is assigned, change your default CMYK to the destination profile, then cycle the document color mode (File > Document Color Mode) to RGB and back to CMYK. This would be slightly less accurate and probably introduce a small amount of extra quantization than a "direct" conversion, as it will use your default RGB profile as an intermediary. The round-trip performance and gamut of your default RGB profile will affect the accuracy. You would likely get the best result using ProPhoto RGB.
If you want to convert CMYK to RGB or RGB to CMYK, then just simply change the document color mode. If you want RGB to RGB, then you'll probably suffer some noticeable gamut reduction if you use any standard CMYK profile as your default.
I've barely looked at CS4 - there may be an alternative way.
  #3 (permalink)
Old 07-07-2009, 11:22 AM
Junior Member
I don't think that it's possible when the document is open but you can do it at opening. If the profile embeded in the document is not the same than Illustrator's working color space, Adobe's application will ask you if you want to convert the colors or leave them unchanged provided that the check boxes dedicated to policies for non-matching profiles (in the window Edition>Colors) are checked.
The conversion will happen just like in Photoshop, using Lab as connexion space but the results are not always what we want them to be: colors that could be achieved with three primaries are often saperated with 4…
Sorry if this explanation is not very clear but I don't have an english version of Illustrator…
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Job Postings from JobsTheyWant
Solutions Finishing and Controls Engineer at Hewlett Packard in Corvallis, OR
Digital Indigo Press Operator at O'Neil Data Systems in Los Angeles, CA
Managed Print Services Sales Executive at Meredith Corporation in Des Moines, Iowa
Key Accounts Technical Color Mgmt Specialist at GMG Americas in Hingham, MA
Account Manager - Commercial Sales at NewPage Corporation in Southeast ( Charlotte, Atlanta, Jacksonville )
Account Manager-Commercial Sales at NewPage Corporation in Northeast (New York, Baltimore, Washington)
Account Manager Commercial Sales at NewPage Corporation in Midwest (Chicago,Dallas,Kansas City, Minneapolis
Services Business Development Manager at Electronics for Imaging in Foster City
WhatTheyThink.com Latest Industry News
ABC board revises definition of magazine
Going Green: Why Graphic Systems Jumped into the UV Screen Printing Pool
New Web-to-Print White Paper by Jennifer Matt Now Available in WhatTheyThink Store
NYU names Bowne & Co. Chairman Prism Award Recipient
Print CEO: Carve the Stone Away: Creating vs. Finding Opportunities
Barton & Cooney adds Pitney Bowes inserting system
PIA releases print production problem-solving book
EskoArtwork to introduce expanded Studio 10 portfolio at Ipex
Pazazz launches Quick Response Codes
FUJIFILM Dimatix Spectra printheads dominate Dongguan China Sign Expo 2010
Print CEO
