Results 1 to 7 of 7
Thread: Acrobat 9
    suzyb1078 is offline Junior Member
    Jul 2009
    21
    Default Acrobat 9
    I am having issues with Acrobat 9. I will work in the program and I may have a few documents open. Sometimes when I go to close a file it will completely shut down my Acrobat. Anyone else have any stability issues with Acrobat 9?
    michaelejahn's Avatar
    Sacramento, California
    451
    Default Troubleshooting Acrobat 9 issues
    Quote Originally Posted by suzyb1078 View Post
    -- please share the following;
    Platform ?
    OS ?
    Acrobat 9 - what ? (Reader, Standard, Pro, Pro Extended ?)
    Acrobat Version 9 .0.?
    What Plug-ins (besides the ones that install with Adobes installer)
    Have you tried repair (Under the Help menu) ?
    Have you visited the Adobe web site --> Troubleshoot system errors or freezes (Acrobat 9 Standard, Pro and Pro Extended on Windows XP)
    This should get you started.
    Hope this helps.
    abccolor is offline Member
    May 2009
    New York, NY
    47
    Acrobat 9 will open each file in a separate window. Are you choosing "close" or "exit" when you want to close a document? Close will close just that window, but exit will exit the program and close all of your windows.
    451
    Default Occam's razor
    Quote Originally Posted by abccolor View Post
    Wow, sheesh - I never thought about the idea that Suzy might be doing that - but i just tried that (I assume you mean the type of 'exit' when I click over the red box with the gray "x" near the most upper right corner of the window - as opposed to the smaller x below that...
    this does not shut down Adobe Acrobat 9 Professional nor will that shut down Adobe Acrobat Reader - it just closes the document (I am on Vista x64) and also tried this using Acrobat standard (on "normal" Vista) if you have multiple documents open, it just closes that document
    Perhaps this is different on a Macintosh ?
    May 2009
    New York, NY
    47
    Clicking the "X" in the corner only closes the window. File-Close vs File-Exit. I just selected Exit and all four of my files (in separate windows) closed. Not what I wanted to do right now with my project, but in the interest of accurate reporting I sacrificed myself. Adobe made a change to the windows version from 8 to 9 in that windows users no longer have the option to set the application to open multiple pdf files in one window. With Acrobat 9 it now works on Windows more similar to that of a mac.
    Sep 2009
    Clearwater, FL 33765
    31
    I didn't face such problem with my Acrobat 9 works fine I think the problem might be because of plugins If you have installed.
    443
    Actually, Adobe changed Acrobat to match the guidelines for both the Windows platform (Vista and later) as well as Mac OS X platform...
    If you have a problem with it - check with MSFT....
    Leonard
