Results 1 to 8 of 8
    gumbylives is offline Member
    Feb 2008
    67
    Default strange font issue in Indesign CS4
    Hi,
    When I open an indesign file it loads all the fonts according to "find font" box, but when I double check to package it, it says it is missing. I have checked the styles and they are not even used. Any ideas would be appreciated.
    Thanks Gumby
    kyle is offline Senior Member
    175
    If a missing font is in a link instead of native content, it won't be moved to the top of the list in the "Find Font..." dialog. Did you scroll all the way down the list?
    Do you see the font in the font list anywhere? This may have changed in CS4, but if a font was only used for paragraph bullets/numbering, it often doesn't appear in the "Find Font..." list.
    You can check the font's file path in "Find Font...." Is it not in a normal font location that no other document font is in? In OS 10.5 and I'm guessing 10.6, the OS will automatically load fonts that it's able to find anywhere on your system drive unless you disable that "feature." Could the font be in a non-standard location and Indesign has a problem with this?
    If you proceed with packaging, is the font file not packaged? If you export a PDF, is the font embedded and do you get any warnings?
    Is there any error if you convert type in that font to paths?
    Feb 2008
    67
    Default well...
    There is no warning in the find font or when CS4 opens the file. Yes I did scroll down. It only gives the error when packaging and in preflight.
    cheers
    Gumby
    1,603
    What font? Could be an empty character, or a hidden layer, or possibly a hidden layer of a placed file.
    almaink's Avatar
    almaink is offline Senior Member
    333
    Did you try saving the file as an interchange? I've seen doing that fix similar font issues.
    dephotoman is offline Junior Member
    Oct 2008
    Ohio
    5
    I tend to think what Lukas says may be the case. We run into this a lot. With your page open go to the menu bar, Type then Find Font. If the "missing font" is listed there, click on it and hit Find First. It should go to the place on the page. Often it is hard to see the cursor as many times it is actually an empty character. If it finds anything you should be able to replace it with proper font in used in your doc.
    Feb 2008
    67
    Default sorry that is not it
    The font is not listed in the "Find Font" dialogue box.
    Feb 2008
    67
    Default Thank you Almaink
    By resaving as an inx file it worked. Thank you for such a great suggestion.
    cheerios
    Gumby
