    Mysterio2099 is offline Junior Member
    Sep 2009
    29
    Default How to make PDFs customers can type into
    Sample image attached.
    I've been trying to find out how to make a PDF like the one in the sample image. It has highlighted fields that someone can type into and then print. No saving required. I've had no luck finding a solution.
    Can anyone help? o.O
    Thanks.
    dabob is offline Senior Member
    Jan 2010
    Around San Francisco
    180
    use the form wizard in acrobat it automatically finds fields that look like they should be filled in and you can add or subtract fields it doesn't get right with the editing tools.
    Sep 2009
    29
    Quote Originally Posted by dabob View Post
    Ah, I never noticed that. I'll give it a shot. Thanks for the tip. Much appreciated!
    Sep 2009
    29
    That was too easy. Worked like a charm! Thanks again.
    michaelejahn's Avatar
    Sacramento, California
    474
    Default be sure to make it reader enabled
    Quote Originally Posted by Mysterio2099 View Post
    When you distribute a form and want people that only have the free Adobe Acrobat Reader to be able to use it - and SAVE what they typed into the form - you need to go under the Advanced menu and select Enable Usage Rights in Acrobat Reader....
    Sep 2009
    29
    Quote Originally Posted by michaelejahn View Post
    I have "Extend Features in Adobe Reader..." I assume that's what you're talking about. If I don't save it this way an Adobe Reader user will not be able to fill in the text fields and print? I'm not worried about the user being able to save changes to the PDF.
