Results 1 to 3 of 3
    rande is offline Senior Member
    192
    Default Removing shadow from Illus file
    Can someone help me with this.
    I'm not a designer but have worked in Illus. before.
    I'm in CS4 I can get rid of this shadow for some reason.
    Its showing compound paths and taking that off doesn't get me to the shadow.
    thanks
    never mind I got it
    dabob is offline Senior Member
    Jan 2010
    Around San Francisco
    180
    Default drop shadow
    open the appearance panel and delete or turn off the drop shadow "layer"
    Screamingbeaver is offline Junior Member
    Feb 2009
    4
    I only have CS3, but i was able to use the direct selection tool, and select the shadow (raster object) and delete it.
