Results 1 to 2 of 2
    dabob is offline Senior Member
    Jan 2010
    Around San Francisco
    180
    Default setting up printers in CS5 . ..
    I am trying to set up a printer to print to a postscript file using Adobe PDF 8 or 9 as a ppd and i am not getting to it . .. . probably a brain fade on friday but could use some help
    thanks
    jfmayer is offline Junior Member
    Jul 2010
    2
    Default Snow Leopard?
    Are you using Snow Leopard? The pdf printer doesn't work anymore. They recommend using export instead. You can still print to a pdf from some applications (just not most Adobe ones) using the OS-based pdf button in the print dialog box.
    See InDesignSecrets » Blog Archive » Acrobat’s Adobe PDF Printer Replaced in Snow Leopard, as well as the comments below that post for details.
