Hi All
I have this strange issue with illustrator files with dielines where a piece of the dieline will go missing if it is on the document edge when you export it to PDF.
Ok here is my example. A 10x10 document with a dieline as simple as 4 rounded corners. The dieline will sit exactly on the document trim edges. Everything looks fine. Export it to PDF with crops and bleed etc. and maybe 1 of the edges of the dieline will go missing. Even when the artwork under the dieline may have bleed and goes past the trim the dieline still goes missing?..
Any ideas?
p
LinkBack URL
About LinkBacks
