Results 1 to 3 of 3
    conte is offline Junior Member
    Aug 2010
    Default Indesign CS3, auto resize textframe
    We have to print addresses on enveloppes. The problem is the lenght of some lines.
    You can make the length of a textframe as big as the biggest addressline, but smaller addresses are way to far from the right side of the enveloppe than.
    Can indesign resize the width of a textframe automatically, how (plugin maybe)?
    pacart is offline Senior Member
    Jul 2009
    105
    not quite understanding this.
    jrhmobile is offline Junior Member
    Feb 2008
    12
    Default Are you centering the lines?
    If you set the frame flush left, you shouldn't have the text movement problems. Also, it'll make it easier to process your mailing through the USPS.
