    Default a CS5 bugg and how to work around it
    Had a customer that had a small caps font "suddenly" loose its caps appearance. The key to finding the issue was the suddenly. Apparently InDesign was not capable of generating small caps when the font in question was in "document fonts" folder. Installing the font in the system, and removing the font from the "document fonts" restored the small caps. Only installing the font did not help. I will report this bug. Don't know if others have experienced similar issues.
    Des Moines, IA
    403
    I believe this was fixed in the 7.02 update.
    Seems to be fixed with some fonts but not all. Just as a quick test tried Minion and it works as it should. Then tried a truetype font, "Hoefler Text", and the bug is still there.
    A great technology but a few glitches to fix
    Jim Restle is offline Junior Member
    Sep 2008
    9
    I ran into this problem twice today. Only one of the jobs I was working on used fonts from a folder titled "Document Fonts". More puzzling for me is the other job worked fine yesterday, but today wouldn't work. I moved the InDesign document to my desktop, and it worked fine.
    Jim
