Have a very simple file that has a white box on top of a colored background tiff image. Both boxes have bleed about 0.5" outside trim. Tried the direct export from ID to PDFX1a using 0.25" bleed and compared to a file generated from the ID to PS to PDFX1a (same PDF settings) and found out that the PDFX1a generated from ID has dark lines from whats under the white zones of my file (not atomic region because they print when sent to my ApogeeX APPE rip) and shows clearly in Acrobat. The PS to PDFX1a doesn't have that problem and is a better representation of the ID file IMO. Any opinion?
I fully agree with Leonard's assessment that we would need to see the files (and I'd also include the source files and joboptions files used) in order to assess what is really going on.
Having said that, if you are using a RIP that directly interprets PDF - and your Agfa ApogeeX RIP with the Adobe PDF Print Engine certainly does that very well, you really should be exporting PDF/X-4 with live transparency and color management! PDF/X-4 was actually specified with that technology directly in mind!
If i am not mistaken the thin hariline is the underliying pixel image?
Does the underlying image have a crop box? If so then what you are probably seeing is in the export to PDF Indesign sees the cropbox as being outside of the bleed, and thus makes it redundant. and so your pixel is not masked as tight as in the PD to PDF workflow. The PS distiller will not be removing redundant masks and therefore give you a cleaner bleed.
It could also be an issue of smooth graphics where the PDF is antialiasing the pixels and therefore you are seing a hairline.
Would be interesting to know, if you have the objects withing printing area do you see the same thing?
If you turn of smoothing graphics in acrobat do you still see the eclipsed bitmap image.
Is it safe to use the Downsampling with Automatic JPEG? I'm assuming it would be since its used in PDF-x4?
I have resisted using this but am getting larger and larger files with image placed in Indesign and scaled down making effective resolutions around 1000dpi each and 3D rendering models and such. Our 42pg magazine that was 830meg exported without downsampling is only 120meg exported as PDF-x4, this is a huge difference but is it 100% safe? I have recently been downsampling but using Zip thinking I'm getting lossless compression, is that correct? This gives me a 530meg file.
TBYLT02_turnstiles_side.pdf is the PDF exported from InDesign CS4
TBYLT02_turnstiles_side.indd.pdf was generated using PS to Distiller
The PDF setting that was used for both is the standard PDFX1a 2001 with downsampling at 72dpi and JPEG High compression (just so I could post my files here)
You can clearly see the line outside bleed area on the PDF exported from InDesign.
Dov, the reason why I use PDF/X-1a is because most publications we deal with require us to do so. I basically use my ApogeeX workflow to preflight/fix the PDFs it receives and to proof them. I haven't found a single publication (magazines, newspapers) that would allow us to send them PDF/X-4...
Dov, Leonard, the attached PDF file is the kind of spec sheet we get all the time from publications. This one has been updated last month and I received it today. As you can see, not only PDF/X-1a is the required PDF flavor but they want you to take the PS to Distiller road. A lot of publications are still afraid to take PDFs that haven't been made from PS.
Oh you didn't tell us the white shape had a drop shadow applied in indesign
If you look at the two as line art you will see in the postscript there is a large white object with a clipping mask. In the file from indesign you have just one shape a "pathfinder" function has been preformed to remove excess object.
You will also always get maths happening as you down sample, and some how the downsampling will be to a grid. the line is less than 1/2 a pixel (if ppi is 72)
now one more thing, if you look at the two files in illustrator you will se a structural difference.
The indesign file is a bitmap has a clipping path and is then in a group. Screen shot 2010-09-13 at 22.17.32.png
In the post script version of this
The bitmap is
…has a clipping path and is then in a group.
…that has a clipping path and is then in a group
...that has a clipping path and is then in a group Screen shot 2010-09-13 at 22.16.32.png
Yes, five levels of groups and clipping paths. (for each atomic region)
Now a drop shadow on the edge of an object would only appear like this on a bleed, sinse else you would have a clipping path around white object, and background or the shadow would protrude.
You are asking why is edge of the bleed not rendered in export, well it is not the artwork, that is what the bleed is for. Postscript does not have bleed boxes by definition, and therefore these will be another level of clipping paths. where all within the artbox is rendered meticulously, including irrelevant information such as downsampled details in the bleed, at the expense of making irrationally complex structure. (I remember the times we had to ungroup groups to get them through the rips).
It is to me an explanation of how those coding must draw the line some where to get rational code and it is up to us to understand those boundaries in which we are to work. In this simple file it seems like a bad decision, but remember the rip needs to render things that are invisible in a file, and had there been lotts of detail outside the bleed you would find that the decision to do away with what is outside the bleed (or should we say aputate since we are talking about bleeding? ;P) is on the whole a good one.
Is it safe to use the Downsampling with Automatic JPEG? I'm assuming it would be since its used in PDF-x4? ...
Downsampling is OK, JPEG is not recommended. I have seen many image quality problems with jpeg compression in PDF creation. Also, check out this article:
<http://blogs.whattheythink.com/blognosticator/2010/08/ansel-would-not-approve-part-ii>
I find it odd that Adobe has JPEG compression on by default in all of the predefined PDF settings, and even more odd that the submission specs say ,"Do not use JPEG compression." and then say to use the default adobe setting which uses JPEG.
@ Bret + Prepper
Might be idea to start a new thread if you have a different topic, makes it easier for all to follow.
In many jobs JPG compression at high or maximum is the least problem to worry about and JPG can be used without perceivable loss in quality, but it depends on the image. A poor quality image will be worse afected than a good image. Noisy images can be really messed up by jpg. But generally the surface of the substrate is more likely to cause image detail loss.
