Results 1 to 10 of 11
    pacart is offline Senior Member
    Jul 2009
    105
    Default Strange Error in Photoshop CS5
    "photoshop can only decode FAX encoded images up to 32767 pixels wide or tall."
    So i get the above error message when i try to open the bitmap image that is created by my Nexus 9.0.3 rip for the plates. The file is a bitmap tif file.
    Anybody run into this, is there a fix? CS3 opens the file just fine, but it does mention the pixel ratio as being different than the default.
    claude72 is offline Senior Member
    Mar 2009
    France
    188
    Quote Originally Posted by pacart View Post
    A 28 inches (71 cm) width plate ripped at 2400 dpi needs a bitmap image with 67200 pixels in its width... but Photoshop can handle only 32767 pixels maximum, and 67200 is more than twice its 32767 up-limit!!!
    Jul 2009
    105
    Then how is it that Photoshop CS3 opens the file just fine? The only thing i have to do is adjust the pixel ratio. Is something different in CS5?
    Julia D is offline Junior Member
    Sep 2010
    4
    Is there a way to increase the pixel maximum by disabling some other features in CS5? I am having to use CS4 to open Prinergy generated tifs. The majority of our files are too big for CS5. I hope someone has a work-around.
    I remember some large format plug in? Check your goodies folder (or some other folder on install) on your install disk, I think there was something about large format support (don't have a disk with me, just going on a memory so may be wrong)
    Jul 2009
    105
    i Got it! With a bunch of help from Dave at Esko, the problem with the file is not the size (33495 x 48496 @ 2540dpi) The problem was the compression that nexus was using. I was using CCITT G4 - guess photoshop doesn't like it, so Dave suggested i use a different compress. I switched to LZW and now the files open just fine. Thanks Dave!
    Sep 2010
    4
    Excellent! I tried LZW - bigger file, but not by too much - and it works fine with Tiff Assembler.
    Is there a way of changing a CCITT file to LZW without opening it, or is that too much to hope for?
    Jul 2009
    105
    I don't think so. sorry. I could be wrong though, it has happened before
    Mar 2009
    France
    188
    ... the problem with the file is not the size (33495 x 48496 @ 2540dpi)...
    ... now the files open just fine.
    But 48496 is over 32767! how can Photoshop handle a number of pixels that exceed its maximum???
    (33495 x 48496 @ 2540dpi is a 13,2 x 19,1 inches image... is it for a GTO?)
    Jul 2009
    105
    well i think you are missing a zero, i am able to create an image that is 300000 x 300000 @ 300dpi in CS5, then the dialogue box pops up and says it may not be compatible with older versions of photoshop.
