yes - that sure is easier then the method I came up with !
Originally Posted by
gig0
The only problem is that it's for certain pages only and also using different colored inserts.
I just found something under Document>Background that just might just do the trick, although I would have to set image transparency to multiply in Pitstop for those pages. Good enough.
http://docs.google.com/View?id=dfwf37zj_1092drchxhfw
It required that we created a special "output intent" profile - the link to the source files no longer work, but you can get the idea - that would be one way - not sure if it is the right way...
