Results 1 to 10 of 15
    destryer's Avatar
    destryer is offline Member
    Nov 2007
    Missouri
    49
    Default Windows Acrobat/PitStop overprint preview issue
    We are having an issue with the overprint preview in Windows not correctly displaying when the color of "black" type is 0C 0M 0Y 100K. Attached is a screenshot of the effect with the black channel turned off. The color warnings "overprint" also indicates that the type is indeed overprinting.
    zoran's Avatar
    zoran is offline Senior Member
    Ottawa, Canada
    276
    Can you post actual PDF?
    Which version of Acrobat, Windows and PitStop? As Zoran said, can you post the PDF or at least this part of it.
    Joe
    Joe is offline Senior Member
    567
    So, do you have overprint preview turned on?
    Joe
    destryer's Avatar
    Nov 2007
    Missouri
    49
    Default PC/Acrobat/PitStop Overprint PREVIEW issue
    Here's a section of the PDF showing the same section as the screencap. I'm interested if this is a Windows/PC Acrobat issue or PitStop issue or some combination thereof. We use WindowsXP, Acrobat 8 and PitStop 9 on our PCs. I have OSX 10.5, Acrobat 9 and PitStop 9 on my Mac and it displays correctly. I can't find a PC that displays it correctly UNLESS I run a PitStop action to convert solid black to gray then run an action to overprint the text.
    gig0 is offline Senior Member
    159
    I can confirm Acrobat 9 on my PC displays it as overprinting. Acrobat 8 on another PC shows it as knocking out. Overprint preview is active on both machines.
    destryer's Avatar
    Nov 2007
    Missouri
    49
    Thanks for checking, we have seen this is an Acrobat 8 preview issue not a PC OS issue since it happens on both the Mac and PC in Acrobat 8.
    In my version of Acrobat (9) and PitStop the black text is set to knock out...
    159
    yeah, thats the bold type knocking out. Check out the line of type underneath the price thats set to overprint. Even Acrobat 7 shows it overprinting in separations mode, but not 8 for some reason.
    Robban is offline Junior Member
    Sep 2008
    2
    I have Acrobat 9, PitStop 9 and Win 7, the pdf looks correct.
