Results 1 to 10 of 16
    assman is offline Member
    Nov 2008
    33
    Default How to Group Paths in Pitstop Pro
    Hi Sir,
    How do I group a selection of paths so that I can simply copy,paste and move to other areas of the page? Thanks for any tips and help.
    I don't think there is a group feature. You'll have to use the selection tool and shift select the items you want to move as a group then use the move tool to move them together.
    Nov 2008
    33
    Hi,
    I can selection tool to select all paths in the logo, however if I accidentally click somewhere then I am unable to select all the logo paths again as there are other paths in the background. Pls adv.Thanks in advance.
    The only advice I can give in that case is to be very careful selecting objects. Unfortunately, the way you're doing it is probably the only way to do it. Sorry there's not an easier answer, but sometimes, the only way is the hard way.
    akalaray's Avatar
    akalaray is offline Member
    65
    Default Moving Items in Pitstop
    Make sure you view in wire frame - To see what you have grabbed, Also good to switch back and forth between views.
    Check out Neo from Enfocus. It's the Sh#t
    michaelejahn's Avatar
    Sacramento, California
    474
    One way I accomplish this is to use the Enfocus Hide Selection tool - that is, I grab thing i DON"T want, go under edit - select Enfocus Hide Selection tool - then select more items, hide them - untill all i have left if what i want - i then select that, copy / paste or move it - then - under the Edit menu, select Enfocus Show All...
    hope that helps!
    There is no grouping function in PitStop. Using Michaels and Ox's tips are the best workable solution.
    Nov 2008
    33
    Hi Bros,
    Thanks for all the useful tips, really appreciate for the effort.
    Quote Originally Posted by michaelejahn View Post
    hope that helps!
    LOL that is so back in the old days of illustrator (AI88) thank's for the nostalgia
    I usually describe PitStop's editing tools that way. Some people get it, most don't.
