Results 1 to 7 of 7
    sureshdhami's Avatar
    sureshdhami is offline Junior Member
    Apr 2010
    13
    Default HP Indigi 5500 Digital some PDf text are not Printing
    We have HP Indigo 5500 Digital Machine, we are inserting text to acrobat Professional and same is not printing in HP Indigo so please advice how can we print in HP Indigo.
    Thankyou
    Suresh Dhami
    Gatekeeper is offline Junior Member
    Apr 2008
    4
    Default Gatekeeper
    Can you post the file for a more accurate answer. a quickfix to convert the fonts to outlines might fix your problem.2) save the file as a postscript and distill again.
    picolorj is offline Junior Member
    Jan 2011
    3
    Default Color overprint option
    If it is a negative text, like white text over a black background, check if colors overprint option is marked. It shouldn't.
    I don't recommend printing large amount of text outlined. It is going to take some time to get them processed.
    Also check what kind of font and that it is embedded in the PDF. You may still have issues with your RIP. The Rip has more to say than the press when it comes to text dissapearing.
    Ultimate's Avatar
    Ultimate is offline Senior Member
    Canada
    129
    Are you using a preflight solution (such as Markzware's Flightcheck?). If not, perhaps if you add this in your workflow you'll save time and reduce wastes on problematic PDF files.
    Ray Duval
    Ultimate Technographics
    www. imposition.com
    Apr 2010
    13
    Dear Gatekeeper,
    Thank You
    Really It work
    Regards
    Suresh Dhami
    TheProcessIStheproduct is offline Senior Member
    Aug 2009
    152
    We had same problem with 3500, make sure you are up to date with all RIP patches and i-fixes from indigo
