Results 1 to 8 of 8
    xcelprint is offline Junior Member
    Nov 2009
    10
    Default Simple question for my simple mind.....
    I am a printer with 30+ years experience, but now I am working with customer supplied pdf files. I have a simple black and white print job, but there are specs and spots on the white background when I print out a copy of the pdf.
    I'm sure there is some way I can "erase" or cover up the unwanted spots. Would appreciate a tip. I have CS4.
    Thanks!
    Mark's Avatar
    Mark is offline Senior Member
    184
    you could always place pages in indesign and put white boxes over spots, if you don't have any pdf editors
    Nov 2009
    10
    Default Thanks
    I will try that. I have acrobat pro 9.1.2
    Have tried under tools, advanced editing, etc but no luck so far. I will try the white box method in ID.
    Thanks.
    buckeye's Avatar
    buckeye is offline Senior Member
    Akron, Ohio
    177
    I find that when jobs come into Pre-Press and they say it's a simple black and white job, it rarely ever is. If you could post a sample of one of the pages, we could possibly give you a couple of suggestions.
    Erik
    pdan is offline Member
    Sep 2010
    58
    Marks answer is simple, safe, least prone to problems. It ensures that your not changing the source file, only improving your end product visually. Get in the habit of using a new layer for your "edits".
    Illustrator can open pdf's, but you will triple your time, with some occsaional unnoticed errors, if you're not adept at the program.
    Photoshop would actually best clean up the artifacts you are seeing, if you are functionally proficient; but would yield far larger files. Avoid Photoshop as well, 1200 dpi raster pages tend to crash or bottleneck a small RIP and network.
    All these hammer and nail fixes assume you are receiving bad pdf's from persons who have no professional ties to the industry.
    michaelejahn's Avatar
    Sacramento, California
    474
    Without understanding what is actually in that pdf that is creating these dots, it is hard to say what approach is best. If this PDF is a scan of a document, you know, where the dot are in am image, you can use the touch up object tool to select - then open - that image in Photoshop, then save it back to the PDF.
    if you are unfamiliar;
    YouTube - lynda.com Tutorial | Acrobat X Essential Training—Editing images and graphics
    This was created by my friend Anne-Marie Concepcion for lynda.com
    If this is confusing, email me privately - michael@composeusa.com - would be happy to help.
    Akila is offline Junior Member
    Mar 2011
    8
    Arrow
    Quote Originally Posted by xcelprint View Post
    Thanks!
    in acrobat you can off unnecessary colors. try it
    DanB is offline Member
    Omaha
    45
    You could use the Adobe Acrobat redaction tool. Before you do, make a backup copy of the original PDF incase you redact too much.
