Results 1 to 7 of 7
    Macmann is offline Junior Member
    Jan 2010
    8
    Default Dashed lines in Illustrator CS5
    Anyone know how to make dashed lines appear dashed in the Outline view. Our plotter
    will recognize the dashed line as a perf (or a score) and apply the appropriate cutter to
    complete the finished piece. Unfortunately we are forced to do a number of work arounds
    to accomplish this now. Any ideas?
    Luc St-Pierre's Avatar
    Luc St-Pierre is offline Senior Member
    Montreal
    138
    Select all dashed lines and go object - expand
    Luc St-Pierre
    Prepress and Color Management
    MacTwidget is offline Member
    Carlsbad, CA
    80
    You could select the line and "Outline Stroke"
    Menu > Path > Outline Stroke
    Jan 2010
    8
    Object expand didn't work for me- a short dash and then a line then a short dash again _ _________________________ _
    Outline stroke creates little rectangles- I need dashed lines. Oh well.
    I wrote David Blatner, the Adobe guru, and he was stumped too.
    Macmann
    How about if you make a pattern brush and then expand will that work? (The expand appearance does some funny stuff with dashed lines, shows what is happening behind scenes with the corner alignment )
    The thing is that you will have to make the pattern a "dot_space-long-space-short" dash since tha pattern a can not srart or end with a space. Then expand as Luc said
    Jan 2010
    8
    Default Pattern Brush
    Lukas-
    Great minds think alike! I created a pattern of 2 line segments, equal in length. I stroked
    one with 1pt black and left the other un-stroked. I "painted" my line with the pattern and then
    chose expand appearance. I then selected an un-stroked segment and chose select similar
    stroke weight, and delete. Now in outline mode I have a perfectly dashed line.
    Now, if only I could explain the concept of bleed to a designer. Thanks for all your help.
    Macmann
    Last time i had to explain bleed I used the analogy of sewing. Turn your T-shirt inside out and explain how the seams can't be at the edge..
