Results 1 to 2 of 2
    MrBuddyLove is offline Junior Member
    Jul 2011
    Unhappy Help in Qlingo Command
    Hello everybody,
    Well I am completely new in this Xmpie world, just 3 days ago i started but i do have some good programming skills in VFP. ok lets start with my query.
    i've just put 3 conditional paragraph thru Qlingo if/then statement, and so far it changes when the unique field change. But within this paragraph there are some variable which are coming from DB, which i want to print in paragraph. i'll put eg.
    <Firstname>, your over draft limit is <Amount>
    i've tried with my little knowledge like |->FirstName and like other with \ commands but doesn't print. it keep printing the above line, it should print like
    Harry, your over darft limit is £1000
    pls help me out. I hope i cleared my question.
    Thanks in advance
    senninha is offline Junior Member
    Aug 2010
    8
    Hi,
    The line should read...
    |->[Firstname], your over draft limit is |->[Amount]
    |->[] is the pointer to the schema (your database).
    Any questions/problems let me know.
    Cheers,
    Mark.
