Results 1 to 3 of 3
    MJNC is offline Member
    Jan 2009
    California
    77
    Cool Acrobat Layer Options?
    Hey PrintPlanet!
    I have an Illustrator (CS5 - v15.00) doc that has many layers; this will be saved as a layered .pdf file (Acrobat 9 Pro - v9.4.5).
    2 things I need to figure out...
    1) how can I make it so that when the layered .pdf is opened in Acrobat that it comes up with a layer locked (that cannot be unlocked in Acrobat) so it is uneditable? and
    2) I also need for the same .pdf to open up in Acrobat with one layer’s view turned off, while still having that layer in the .pdf so it can be turned on and viewed when needed.
    I've been checking around in both apps, and I am not having any luck with finding where to edit these param’s. Has anyone out there on the PrintPlanet ever had to figure these things out? Thanks in advance if you can help me... I appreciate any ideas I can try.
    Peace to the PrintPlanet!
    _mjnc
    CHM
    CHM is offline Senior Member
    May 2008
    171
    To lock a layer you can do that in Acrobat, by changing the layer properties.
    For hide a layer, just hid it in Illustrator and it will come the same way in the pdf.
    But you will have to save the pdf directly from Illustrator.
    Jan 2009
    California
    77
    Cool Acrobat Layers
    Hey CHM;
    I thought I had tried saving the .pdf out of Illustrator with the view turned off and it didn’t stick in Acrobat. When I received your post I tried it again, and it does work.
    Regarding the locking issue; I am aware of the Layer Properties available in Acrobat. I can lock a layer this way, but if the client knows anything about Acrobat they will just go in and unlock it. I guess, however, that that’s going to have to do.
    Thank you so much for the info! Have an outstanding day.
    Best,
    mjnc
