Results 1 to 5 of 5
    JLRobertson is offline Member
    Nov 2009
    30
    Default Acrobat or InDesignCS4 script to print discrete pages
    I have received a PDF with thousands of financial-type statements that will be printed as individual stitched booklets and mailed.
    Is there some kind of scripting available that will enable Acrobat or InDesign CS4 to print the file in sets of 8 (ie pages 1 through 8 is the first booklet, pages 9 through 16 the second, and so on) to my booklet-making copier?
    OS 10.4.11 on G5s ...
    Amer is offline Member
    Oct 2008
    Rijeka, Croatia
    38
    Yes, there is, right in InDesign and its named surprisingly, print booklet .
    Choose perfect bound, and signature size of 8 pgs and you're done. Provided of course, you're printing it 2-up (for 4-up, etc. you will need some kind of imposition product - there are too many to mention).
    However, you have to place the pages in InDesign first. There is a script (Multipage importer) that will do it for you.
    You might also have the option to do all this on the RIP of the copier, but since you did not tell us what it is, we can't help you there.
    Nov 2009
    30
    It's printing off a KM650, folded and stitched inline on the copier (Creo RIP) which does not have the capability to separate out the individual booklets and needs single pages for its saddle stictch option.
    1,594
    Do you use hotfolders? In Acrobat you can split a file using the command, you guessed "Split Document" in the pages tool (Acrobat X) acrobat 9 it was in a menu somewhere. You can choose to split by file size or number of pages or even top level bookmarks, and get option to name your parts.
    If you have a hot forlder system then you should get a booklet per file? You should be able to batch print the files and them being split into documents ought to be enough for any workflow with a brain to figure out they are not to be re-combined
    Nov 2009
    30
    Thanks Luke, definitely points me in a good direction!
