distiller lost presets
Using Adobe Distiller 9 on my MacBook pro, 10.6.8
Never had an issue before, I dont use it very often, maybe a few times a month. Today I was going to distill a .ps file, and found that all my presets were gone, save 2 of them, PDF/X-1 and PDF/X-3. There were about 5 different settings I had and used at different times. Today they are gone, I tried adding the settings again, they are still where they should be: Library>Application Support>Adobe>Adobe PDF>Settings, but it wont add them in, just keeps the same 2
Anyone know whats going on here and what I can do to get my presets all back? Would rather not do an uninstall and install again if I can avoid it.
Have you tried trashing your distiller preference files?
Greg
Premedia Software Inc.
Although it should do the same thing, have your tried running up Distiller, then using the Settings > Add Adobe PDF Settings menu?
I agree with Greg, trashing the Acrobat Distiller.plist file may help - it often does with Adobe application problems!
Of course, someone may ask - whey are you still Distilling? Exporting/Saving direct to PDF from Adobe Apps is the modern way of doing things.
