Results 1 to 10 of 15
Like Tree2Likes
Thread: Zapf not embedding
    kaiserwilhelm is offline Senior Member
    Nov 2007
    289
    Default Zapf not embedding
    I am attempting to upload a file with this. The font used for the box is Zapf Dingbats. I have tried EVERY variant of zapf that I can find. (True type, PS, even an open type that is not truly Zapf)
    I utilize another piece of software that allows me to use this font.
    So, I export out of Indd CS 5.5
    I then do an acrobat - file - properties. It shows embedded.
    however, just for fun, I select the box with Pitstop and attempt to change the box from a "Q" to another letter. Instant blank space.
    I then bring it into my other software with the same result.
    Is there something about Zapf that I am not catching?
    735
    My guess is that the font is not fully embedded, but subsetted, and that the attempted substitute character is not embedded.
    curveto is offline Member
    Mar 2011
    Scottsdale, AZ
    46
    Correct.
    I looked at the file (with a HEX editor) and the only /Font objects (I found two) are subsets. Try your export again (checking the appropriate boxes).
    Nov 2007
    289
    I will gladly upload the file with my export settings if I can upload a zip? I changed from subset at 100 to subset at 0. Both give this. I am almost positive this is a Zapf issue only. I can put in 10 other fonts and they are all fine.
    735
    You have not explained what is the purpose of engaging us in any of this. In your first post you state:
    "however, just for fun, I select the box with Pitstop and attempt to change the box from a "Q" to another letter. Instant blank space."
    Zipped files upload just fine. But why do you want us to look at another file, "just for fun"?
    Nov 2007
    289
    Al, I am using Pitstop to save me time prior to going into another software. I believe that if I cannot get it to show up in its entirety in Acrobat with Pitstop, then why bother with the other software?
    I guess Just For Fun was not the proper term.
    735
    In other words, you are preflighting your pdf with Pitstop. But why do you need to change the Zap Q character there?
    Have you considered that you may be using Pitstop improperly?
    Are you positive that only one version of the font is active in your system at the time?
    Have you posed this issue in a Pitstop forum, or contacted their technical support? Might there be a Pitstop preference not set correctly?
    Nov 2007
    289
    No, Al. I am only using Pitstop to "see" what I have. I really am believing that this has something to do with Zapf. I cannot replicate this on any other font. That is why I put this in the Adobe forum. I figured it was an Adobe font.
    I have one version of zapf on. I use Universal Type Server and my system fonts do not include a zapf.
    If I look at properties of the pdf, it shows that zapf is embedded. In my opinion, it is not. If it were embedded, it would allow me to change from one letter (Q) to another (H).
    735
    Repeating my #3: "Have you posed this issue in a Pitstop forum, or contacted their technical support? Might there be a Pitstop preference not set correctly?"
    Also, does this other unnamed software recommend Pitstop as a criterion for checking pdf files before they are submitted to it?
    Have you contacted tech support for this other unnamed software?
    735
    Are there other Pitstop users on PrintPlanet also having problems editing pdf text in any Zap Dingbats version?
