So I recently found with multiple files over the course of the last few weeks Output Preview on multiple machines is not accurate.
Pitstop inspector will identify type or a black bar for example as 100% K. Opening in Illustrator yields the same result.
We like using output preview to quickly identify 4 color blacks that we will correct before output. Turning off the black channel on some files yields a mix of CMY remaining. Values in output preview indicate a rich black, preview as a rich black, yet it most certainly isn't.
Hi i had that same issue before and i realized that if you dont refresh output preview for each pdf you open it will still have the results from the previous pdf, as far as giving incorrect readings for black or spot colors
Hope this relates somehow?
Duncan
I know exactly what you're talking about but unfortunately that's not the case here. Multiple machines, fresh program launches, inaccurate results.
Output preview/separations by default will usually show the *expected conversion* of elements, rather than what the current element build values are (such as RGB text showing up as CMYK, when at the object level it is still currently RGB).
The output preview/object inspector does show the *true, current* file values. It is not a live reading as one moves the cursor around the file, one has to click on each object to obtain a reading.
Not sure if this helps or not, I am still using v9.
Not sure this helps in our case either... The objects we're trying to read are confirmed to be 100% K yet the inspector displays a rich black.
First and foremost, we need you to post an actual PDF file for us to be able to confirm all of your assumptions about the data in the PDF vs. the presentation in Output Preview. Screen shots are useless as we have no actual data to work with.
Second, it appears from your screen shots that the PDF is _NOT_ a PDF/X file, but instead a "regular" PDF. As such, it is even more important to see the PDF since we don't know if your CMYK data is actually "DeviceCMYK" vs. an ICC-profiled CMYK. This makes a HUGE difference when using Output Preview, since there is a possibility for color conversion due to your choice of Simulation profile.
What does the Object Inspector in Output Preview show?? Does it show the object as DeviceCMYK or ICCBased CMYK? OR other...
Object Inspector shows ICC Based CMYK. Why is it previewing fine in Acrobat 8 and not Acrobat X? I'll attach the file.
I should add that when the pdf is created out of indesign as a single page file, it is fine. We drop it in a hot folder to impose the file for digital and the imposed file previews incorrectly. It seems completely random... happens with supplied files as well. Again, Acrobat 8 is always correct at displaying the separations.
