Results 1 to 10 of 13
Like Tree1Likes
Thread: Exporting to PDF . .. Naming Questions???
    dabob's Avatar
    dabob is online now Senior Member
    Jan 2010
    Around San Francisco
    583
    Default Exporting to PDF . .. Naming Questions???
    I have been having this issue for a while but it seems to be getting worse. When I use the export to PDF function sometimes it exports it with the file name and other times it exports it with some other file name that apparenly has little or no relationship to the file . . .
    Anybody else noticing this????
    If you have what did you do about it????
    Colorblind's Avatar
    Colorblind is offline Senior Member
    Montreal, Qc, Canada
    425
    On a mac, you can automate PDF export from InDesign with scripts using any predefined PDF export preset. Just paste the following code in AppleScript editor (it will also take care of your file naming issue), then click "Compile" then "Run". Alternatively, you can save this as an AppleScript application and double-click on the app icon to run it:
    --script by Colorblind, tested with InDesign CS5.5 on MacOS 10.6.8
    --this script exports all opened InDesign document as PDFs
    set my_destination to (choose folder with prompt "Choose destination for the PDFs") as string
    --if using InDesign CS5 change "Adobe InDesign CS5.5" for "Adobe InDesign CS5" in the following line
    tell application "Adobe InDesign CS5.5"
    activate
    --next line collects all current PDF export presets
    set my_pdf_export to get the name of every PDF export preset
    --next line makes you choose which preset to use for ALL opened InDesign documents
    set my_pdf_choice to (choose from list my_pdf_export) as string
    --loop starts here
    repeat with this_doc in (get every document)
    --next line gets the name of the active InDesign document
    set doc_name to get name of this_doc
    --next 3 lines perform the actual PDF export
    tell this_doc
    export format PDF type to my_destination & (characters 1 thru -6 of doc_name) & ".pdf" using my_pdf_choice without showing options
    end tell
    end repeat
    set volume 5
    --beeps 3 times when all PDFs are exported
    beep 3
    end tell
    --The Finder will try to open the destination folder
    try
    tell application "Finder"
    activate
    open my_destination
    end tell
    end try
    hux likes this.
    547
    As far as I can tell, the very first time you export a PDF it will automatically use the file's name. If you change the name of the PDF upon export, ID will remember that name the next time.
    Dan Curry
    Prinergy 5.3 • Preps 5.3.3 + 6.3
    cjwworld's Avatar
    cjwworld is offline Junior Member
    Apr 2013
    Nevada, MO
    16
    I agree with DCurry.. It will remember the changes. So I would not change the name and let it remember that. If for some reason you want to make a change, do that after exporting.
    dabob's Avatar
    Jan 2010
    583
    Whats happening mostly is that I will open up a template file or a previous business card order and make the changes and save it under the new job # and description and then go to export it and it holds onto the template name or the previous file name. If I change it - it doesn't always remember it . . . I'm clueless as to why this is happening since it doesn't happen all the time?????????????
    1,796
    If you are on a Mac, have you tried the AppleScript previously posted? Do you need help compiling the script?
    If you are Windows based, there should be a similar JS or VB script floating around the web...
    Perhaps try doing a save as to the INDD file after you export to PDF, so that the exported file name sticks? When exporting the PDF you can also click on the INDD file so that the PDF inherits the INDD name (remember to change the file extension to .pdf).
    arronlee is offline Junior Member
    May 2013
    Los Angeles,California,United States
    9
    I agree with cjwworld.
    Do not change the name and let it remember that, and then changge it after exporting if neccessary.
    BarbWPP is offline Member
    Mar 2012
    Topeka, Kansas, USA
    76
    I have also seen this happen, with Windows 7 and older, anyway. 99% of my files come from other people (I work pre-press). I believe that the previous user of the file exported a pdf or other export file type, which would pick up and remember THEIR filename. Just rename when you export your pdf, and it should remember that in future. If getting the SAME filename in there is essential, a script may well be the answer, otherwise I do a copy/paste from the InD file to the pdf after the pdf has been created, if needed. Then, on a Mac, you can click on the pdf filename in the export window if you have to export again, and it will pick it up from there and then remember the new name.
    samB is offline Junior Member
    Jun 2012
    Chicago
    9
    What was said above is correct. (mac experience here, not enough PC work to know this for sure)
    If the name was NEVER changed it will default to the file name. If it was EVER changed, it will remember the old name.
    Same thing goes for paths. NEVER=Current Directory, EVER=Last used directory.
    I'm unsure if changing only the path also stops the name from ever changing.
    Your only options once the export name has been changed are a script (which I never thought of), or starting the file over. If the file is not too complicated (or well designed) you can export to .idml and re-import. This is the same as doing the file over, without having to do the file over. There's always a chance of a hiccup in the double conversion however.
    Afterthought: "Packaging" the file also starts the naming schema over again. I tend to package a lot of files anyway, to keep everything together.
    dabob's Avatar
    Jan 2010
    583
    Thanks for all the advice . . . its basically what I thought only better said . . . . I guess I will just have to be careful when exporting pdfs from an altered file - not a big deal as things go - just a small PITA.
Powered by vBadvanced CMPS v4.1.2
