Standard Finishing
4OverXerox
Announcement
Collapse
No announcement yet.
OKI C931e
Collapse
Canon
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Shawnd
    started a topic OKI C931e
    OKI C931e
    Just got one in, first impression, this printer is huge! This will be replacing our Xerox 7400 for printing envelopes. We are waiting to get the Straight Shooter LF Pro Plus envelope feeder in to match up to this since our old Straight Shooter LF-12 won't work on this printer, trust me we tried, it won't work. The 7400 gave us issues with embossing, from what I was told this 931 won't have that issue.
    Any questions feel free to ask.
  • Shawnd
    replied
    I wanted to update with something I found on OKI's website that now has my printer working great, not nearly as many stops for adjustments.
    https://okiprinting-en-us.custhelp.c...d/25692/p/6104
    I updated to the latest firmware and made some of the recommended changes to settings and now my 931 flies. Wish I had found this sooner.
    Leave a comment:
  • methogod
    replied
    its a XF fiery, havent messed with it at all. just finally got new belts for the straight shooter.... I do know i need some help figuring out how to do Variable data - with a regular fiery, i know how to do it. Even simple stuff like setting a template/background doesn't seem to work on the C941
    Leave a comment:
  • Shawnd
    replied
    Which fiery did you get with it? Your the first person I have seen with a fiery hooked up to one.
    Leave a comment:
  • methogod
    replied
    We have always had the C9000 series and use them till they die, think i am on the 4 or 5th one. We duplex long flap remits, and can run PEW envelopes that no one else seems to want to (without the feeder). Just got a C941, eager to run clear and white, just getting it running with the external fiery - like it alot, going to prob get a C931 to replace the C9000 when it dies... which wont be too long...
    Leave a comment:
  • Shawnd
    replied
    I use the straight shooter, I can load up about 100-150 remits at a time and it does a good job at feeding them into the printer.
    Leave a comment:
  • JustinB
    replied
    How about a few pictures of how you feed remit envelopes through your envelope feeder?
    Leave a comment:
  • Shawnd
    replied
    Wow, can't believe it has been 2 years already. We have over 500,000 clicks on the printer and it is still going strong. We must have got a defective media thickness sensor straight from the factory because the machine was sooo finicky about envelopes (paper jams out the wazoo) till we replaced that a few months back, now it will run anything we throw at it, even does remit envelopes duplex at a good speed, was surprised at that. We just had to run 16pt 6x9 postcards through it to burn an address/barcode on that we couldn't get the inkjet to dry on the coating, handled them like a champ, wasn't the fastest but it got the job done. Quality is still good, much better than a memjet that is for sure.
    The only thing I wish it would do is not stop so often for temp adjustments, even on light setting it will do it every 30-40 envelopes, it stop for about 30 seconds then start again.
    Leave a comment:
  • Shawnd
    replied
    Just wanted to do an update, we got the new Straight Shooter in and man is this printer quick, 1 #10 envelope per second, 6 x 9.5's were not much slower, maybe 1.2 seconds per envelope. Quality is good so far, we mainly are printing color logo's / return / permit and variable data addressing.
    Embossing is not an issue anymore since we have more control over this printer.
    Leave a comment:
  • Shawnd
    replied
    Fixed the issue, mpt tray was set to com-10, in order to print correctly it needs to be set as letter size in order to change weights and paper settings.
    Leave a comment:
  • Shawnd
    replied
    We are having issues with the envelopes sealing after running through the printer, I have tried about every setting I can think of. Played with the weights going from ultra light to heavy, tried plain paper settings as well. Tried different envelopes, even western states digi-clears and they all seal going through, switching the media to ultra light does help with the sealing but it still happens. Having to send samples to OKI to see if they can figure out the issue. Anyone else run across this and found a fix?
    Leave a comment:
4OverCanonKBATharsternAvantiXeroxSmartsoft (Presswise)Duplo
Automation Article
Collapse
Avanti
Why Would You Ever Want To Automate?
It seems far too complex, costs money, involves a lot of people, will take time etc etc. And then you run out of excuses. Read the article.
CanonXeroxSmartsoft (Presswise)DuploTharstern
What's Going On
Collapse
There are currently 5804 users online. 88 members and 5716 guests.
Most users ever online was 6,611 at 11:23 AM on 02-27-2019.
Working...
X
