S
SE Printer
Guest
This is a 350gsm uncoated stock.
Using a versant 80
The image attached shows printer settings .
enhanced text
max printer density disabled
image smoothing disabled
text & graphics quality - normal
We have since printed again using Printer settings:
Max printer density enabled
150 dot (200 and other settings just cause the image to look SO grainy/dark)
image smoothing enabled
Text & Graphics quality - best
MANUAL DUPLEX
Tested the image transfer adjustment set it to higher then lower and couldn't see any difference to the ink coverage.
Also tried slowing the paper down through the fuser to the lowest thinking this would work but it didn't improve things
its definitely better but not as good as we would have hoped!
Is it just the uncoated and weight stock?
Can anyone suggest anything else to try - its so frustrating!
Many thanks
Using a versant 80
enhanced text
MANUAL DUPLEX
Many thanks
