Standard Finishing
Xerox4Over
Announcement
Collapse
No announcement yet.
Ink pilling on Impression cylinder
Collapse
Canon
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Thielen Solution
    replied
    Originally posted by pacificiam View Post
    Thanx for your input.
    can you suggest from where we ll get this wax?
    We are printer from India.
    My name is Paul Thielen....I invented the "Thielen Solution" back cylinder paste in 1988.. It is still available. It was also private labeled under many different names. Contact me at pthielen572@gmail.com
    Leave a comment:
  • Thielen Solution
    replied
    Leave a comment:
  • Denny mc
    replied
    Try car wax. Wipe wax on let dry wipe off
    Leave a comment:
  • omArabian
    replied
    check the pressure ( cylinder - blanket ) you will fined it high.
    Leave a comment:
  • rickpro
    replied
    might seem too obvious but I would also ensure you are not putting down too much ink on the first pass and/or unbalanced ink/water thereby causing emulsification and an ink film that will never dry!
    Leave a comment:
  • D Ink Man
    replied
    You need to go to a high solids, low petroleum solvent type of ink formula. AS a general rule of thumb for the press person, the ink should NOT STAY OPEN any longer than "8" hours in bulk.
    Usually quite an easy fix via the ink medium. D
    Leave a comment:
  • turbotom1052
    replied
    if the press is a perfector press what is the condition of the impression cylinder jackets?
    Leave a comment:
  • witchal
    replied
    An old school solution was to clean the cylinder well or even polish it then rub it down with fountain concentrate (not solution). Repelex was always the best.I'm not sure if that is still sold.
    Leave a comment:
  • Alois Senefelder
    replied
    Orientation!
    Hello Al,
    mmm I wonder which Orientation, anyway a PDF for your perusal.
    Regards, Alois
    Leave a comment:
  • nhprinter
    replied
    First thing that will solve your problem is better ink. If that's not available a simple wipe of your impression cylinders with a good liquid silicone such as Prisco Slide will help quite a bit. You should also consider getting rid of the IPA at your next roller change.
    Leave a comment:
  • Coastline
    replied
    ABC Allied Ink Repellent
    ABC Allied Ink Repellent does the job, please see attached.
    Leave a comment:
  • Al Ferrari
    replied
    Originally posted by Alois Senefelder View Post
    Sorry - never thought about that.
    So for you orientation plays no role in prepress?
    Al
    Leave a comment:
  • Alois Senefelder
    replied
    oooooooophs
    Hello Al
    Regards, Alois
    Leave a comment:
  • Al Ferrari
    replied
    Alois,
    Are you aware that those pdfs need to be rotated 90 CW?
    Al
    Leave a comment:
  • pacificiam
    replied
    Hello Pacificiam,
    Clarification of the problem?
    1) Do you have assisted drying at the delivery end of Press e.g. I.R.?
    2) If not, by extended drying you mean longer time interval between printing 1 side and back-up?
    3) Are you using conventional Oxidation type litho inks?
    4) Are you using Foreign/Indian manufactured Inks?
    5) Are the Plate/Blanket/Impression-Paper NIP pressures correct?
    Finally, in my opinion the problem lies with poor Ink/Paper relationship, e.g. Ink Absorbency
    Regards, Alois
    2 PDFs that you hopefully will find interesting
    Dear Sir,
    Thank you for your data.
    1) Our press is enable with IR dryer
    3) Yes!! Our conventional inks is oxidation type
    4) We are using Indian inks.
    5) All nip pressure is correct. We are facing this problem on our all multicolour m/c
    Leave a comment:
CanonKBAAvantiSmartsoft (Presswise)DuploEnfocusXerox4Over
Canon Embellishment White Paper
Collapse
Print Embellishment Goes
Straight To The Bottom Line
InfoTrends reported that interviews with more than 100 print customers demonstrated an appetite and willingness to pay premiums of 24% to 89% for special effects, over CMYK-only printing. They also indicated embellishment could apply to a significant portion of their work. Embellishment options can include hot foil stamping, spot gloss UV, embossing, debossing, letterpress, diecut shapes, lamination, duplex, triplex, gold foil, silver foil, copper foil, white foil, black foil, clear foil, etching, and laser cutting techniques. Download The Free White Paper.
CanonSmartsoft (Presswise)AvantiKBAAvantiEnfocusGraph ExpoDuploXeroxChili publish4Over
What's Going On
Collapse
There are currently 7691 users online. 123 members and 7568 guests.
Most users ever online was 10,745 at 04:03 PM on 10-10-2019.
Working...
X
