Agfa avalon lf model -e (error a0552)media handling failure.
CAN SOMEONE PLEASEHEP ME FIGURE THIS OUT?
Does anyone know steps to recalibrate the motor?:D
This error could be generated for many reasons like failure to load and unload the plates or low vacuum pressure or...... What you will need to do is to describe the problem. Was there a plate jam during load/unload process? If you only feel motor calibration will resolve the issue, then this can be found under tools....Avalon lf control ..... servo motor calibration of UNIDIAG software. Hope this will help!
Thank you Armya
Thank you Armya
We figured out that the motor end up failing, may I ask if you know an sources where I could buy avalon agfa lf output motor CG+034520502 ?
Thanks for your help in advance
How did you figure this out? I have never seen one case of Motor failure for this error.Did calibration failed for this Motor?
May be this is time to describe the problem from start to end, if you feel I might be any help . I also emailed you the price of the motor as well.
