Bill W
Greetings,
I have decided, since I am in the middle of running G7 targets, to adjust my Lab values to the ones listed in the 2007 spec. They are not that far off of the 2006 values but I figure I might as well be as up to date as possible. I see that the RGB Lab values are not listed in the 2007 spec as they were in the 2006 "How To...". Does anyone know if those numbers are available?
I am the pesky flexo printer that has discovered that while I can meet the solid CMYK values under both the 2006 and 2007 guidelines, I could not get a close to the RGB values as I would have expected to considering my solid CMYK dE's are less than 2 to the CMYK values. I am sure the problem is ink trapping, but I would like to know the new numbers so I have something to compare to.
Thanks to all that answer.
