Standard Finishing
Xerox4Over
Announcement
Collapse
No announcement yet.
Plate developer machine and hard water issue
Collapse
Canon
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • Plate developer machine and hard water issue
    Hello there!
    What if you - like me - live in a VERY hard water area and have to deal with your CTP plates?
    The problem is deposits on the rinse machine.
    We already have some decalcifying stuff but it's not enough!
    What about put some kind of anti limescale into the rinse water close cirquit?
    I'm thinking about vinegar...
    Could it really be too bad for the plates?
    thanks!
  • #2
    Hello darioluca,
    Question: 1) Are you having " On Press Plate troubles" if so what are they ??
    2) the use of "Vinegar" NO and 3) Use Reverse Osmosis Water Treatment.
    Regards, Alois
    Comment
    • #3
      No issues on the plates, only in the machine (limescale deposit).
      We already Use Reverse Osmosis Water Treatment but apparently it's not enough.
      Why not some acid pouring in the rinse water?
      Comment
      • #4
        Rent a DI unit for a couple of months and see if that helps
        https://www.axeonwater.com/blog/deio...r-vs-di-water/
        Comment
        • #5
          A home use water softening system e.g. ion-exchange should work. Look for a medium size one to supply enough water volume for your machine. Don't bother about extra sodium into your rinse water it's ok for plates. Monthly cost of consumable resins and salts is reasonably low.
          Comment
          • #6
            Hello darialuca,
            The manufacturer of the Reverse Osmosis Installation is responsible FOR delivering the water to your " Specifications and Standards".........IF NOT WHY NOT ...... so sue them !!!
            Regards, Alois
            Comment
            • #7
              That's a good point!
              Comment
              CanonKBAAvantiSmartsoft (Presswise)DuploEnfocusXerox4Over
              Canon Embellishment White Paper
              Collapse
              Print Embellishment Goes
              Straight To The Bottom Line
              InfoTrends reported that interviews with more than 100 print customers demonstrated an appetite and willingness to pay premiums of 24% to 89% for special effects, over CMYK-only printing. They also indicated embellishment could apply to a significant portion of their work. Embellishment options can include hot foil stamping, spot gloss UV, embossing, debossing, letterpress, diecut shapes, lamination, duplex, triplex, gold foil, silver foil, copper foil, white foil, black foil, clear foil, etching, and laser cutting techniques. Download The Free White Paper.
              CanonSmartsoft (Presswise)AvantiKBAAvantiEnfocusGraph ExpoDuploXeroxChili publish4Over
              What's Going On
              Collapse
              There are currently 5299 users online. 97 members and 5202 guests.
              Most users ever online was 10,745 at 04:03 PM on 10-10-2019.
              Working...
              X
