Pitstop Help hotfolder?
Chasfinch
Hello
Has anyone generated a script for PITSTOP to use a specific preflight action?
to clarify a bit I am using XMF which allow you to put in a PPP file (preflight) and get a report. Problem is first and foremost it is all done in mm and you cannot change that. Also it does not work consistently like right in acrobat. So if I could create a hot folder and have it right the report in the "finished" folder that would be awesome
