Cropping to visible objects?
StillWaiting
Hi guys,
Is one might be a tricky one. Can a crop to visible objects be done? Please see the attached screen captures. Ones in color mode, the other in line mode. It's a complicated Esko PackEdge Markset that has a sliding white box to the right that I always have to then open in Photoshop and crop down when the 1-bit tiff is made to get rid of the dead space.
Callas pdfToolbox can do that (and many more). I tried it in the most recent version, but the fixup (Crop to Visible Based on Rendered Image) is available since version 10. Please see your example fixed.
  • test_fix.pdf
I'm looking for an answer from abc. I'm using PitStop with Esko's Automation Engine.
Sorry it took a while, start of the year is always a little manic.
Yes it can be done in PitStop, but not with the PitStop implementation currently in AE. I'll check with the AE Product Manager, but next release I assume it will be included.
You can PM me if you want further details.
Thanks. We are currently only on AE 16.1. Oh well.
