CreoScitex Brisque Network Unreachable. HELP!!!!!!!!!
DiegoPR
Please help me to solve this problem.
We been working for a couple of years with a Brisque Impose station. Two days ago show a problem.
When the system start I get this message: afpsrv [9288] sendEvent: Network is Unreachable.
If I login as cdesc, the Brisque 4.0.97 Software is not fully functional.
I try to do this, login as root, enter Scismit, software handling, display software versions; the report status show me that some of the filesets are not installed. :(
I try to reinstall the Brisque software, but the installation fail because it does not find fileset.
If someone have a clue on how to fix that, please trow me a bone here.
Thanx
Re: CreoScitex Brisque Network Unreachable. HELP!!!!!!!!!
A few years ago we had a similar problem
The creo technician just unplugged everything and dusted and sucked all the dust
Waited a few minutes and as for magic everything worked as before
The station was on the floor and collected dust and crap
I hope that is something similar for you as well
Cheers
Maybe your hd is failing or do a cold start install but erase the disks or format them in a pc and block the bad sectors with the adaptec utility
Sounds to me like a network card issue or an Appletalk configuration problem. Sorry I couldn't be of more help, I don't speak Unix very well.
