Standard Finishing
4OverXerox
Announcement
Collapse
No announcement yet.
Creating tabs?
Collapse
Canon
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • bcr
    started a topic Creating tabs?
    Creating tabs?
    Curious as to how people currently produce tab sheets.
    Currently i use auto tabs in fiery jobmaster which creates tabs from bookmarks.
    Downsides of this are if you have hundreds of documents to print with tabs, you first have to compile them into a single pdf. This takes time and creates a huge pdf which is slow to print.
    I think that the ability to automatically create tabs based on the filename of a sequence of docs would be faster. Any thoughts/ recommendations?
  • printmore
    replied
    Hi
    Fiery Job Flow has a workflow for what you are describing which possibly could be modified to suit your requirements.
    Here is a link to the workflow summary:
    https://www.efi.com/library/efi/docu...y_fg_en_us.pdf
    Hope this helps.
    Leave a comment:
  • minch
    replied
    I have only used EFI Compose to create tabs - most of the people I temp for are running old equipment here in the UK as commercial printing is so cut throat.
    Leave a comment:
4OverCanonKBAAvantiXeroxSmartsoft (Presswise)Duplo
Automation Article
Collapse
Avanti
Why Would You Ever Want To Automate?
It seems far too complex, costs money, involves a lot of people, will take time etc etc. And then you run out of excuses. Read the article.
Canon4OverKBAXeroxSmartsoft (Presswise)DuploAvantiXeikon
What's Going On
Collapse
There are currently 5168 users online. 72 members and 5096 guests.
Most users ever online was 6,611 at 11:23 AM on 02-27-2019.
Working...
X
