Compare 2 PDF files
ecarbone
I am looking for software that can compare 2 PDF files and show the differences.
As an example: We prepare a high-res, print-ready 1-up optimized PDF file for an envelope and send it to an envelope printer. They build a new file (for conversion) on a larger sheet, run it through their workflow and send us back a PDF proof. So in some cases the PDFs we want to compare are not the same size or in the same position. Many years ago at the print show in Chicago I saw a software program that did this, but I don't remember the name of the company. Consumer-grade pdf comparison software won't work for me, and pre-flight software kinda gives me an idea but the software I'm talking about allowed you to position one PDF on top of another and it visually highlighted the differences and let you know what changed.
Thanks all.
Hello,
Acrobat DC now ships with Compare Files (see icon)
This will compare text and objects and report on the differences. It is a handy tool but if might not show up changes in CMYK colour builds etc.
All the other software I have seen compares text in two files (Nice if you have a contract with small print) but nothing that compares files for the things Pre-Press care about.
The feature in Acrobat for comparing PDF files should not be relied on for considering detailed graphic arts attribute comparison, but rather, gross level comparison of text.
- Dov
If you happen to be working in Adobe Illustrator then Esko’s DeskPack Viewer plugin for Ai may help. With it you can select two files that can open in Ai and a separate scalable window comes up. The two files can be viewed in overlay with the differences highlighted (as in the screenshot attached), show only differences, and of coarse a side by side view with differences shown. There are several other valuable QC tools included in the Viewer.
You can try for free - https://www.esko.com/en/products/deskpack/plugins
Click image for larger version  Name:	Screen Shot 2018-09-08 at 6.43.23 AM.png Views:	1 Size:	155.4 KB ID:	278817
Kodak PDF Compare does exactly what you require, but I don't know if the license is available separately. Ours is licensed through our Prinergy workflow
Global Vision's Quality Control Platform can compare PDF files and highlight changes, both for graphics and text.
It also has several other features. Have a look here:
Kind regards,
Michiel
As mentioned above, Global Vision has a good solution.
PC Industries also has a good solution.
http://www.pcindustries.com/product/guardian-olp/
AVT has one as well.
https://www.avt-inc.com/solutions/of...ons/softproof/
Eye-C has one too.
https://www.eyec-america.com/solutio...ss-inspection/
Packz is a PDF editor that has a feature built in to compare files.
https://www.packz.com/
They all let you open different file formats including PDF and Illustrator. I am not sure that Packz will let you scale for comparison, I think you will need to first scale the file within Packz before comparing. Of the first four options I had a preference for Eye-C but they all worked really well and would recommend you do demos with them. They should let you send them files to test with so you can make sure it works for you. I only did demos with the first three softwares and never actually used them. I do use Packz and I haven't had to compare different sized files. Usually the page box might be different but I can easily adjust this within the software. Since I have Packz I don't have a need for a separate PDF comparison software.
The demos I did for the other software was at a different job and it was intended to be used outside of prepress for PDF approval purposes.
