Preflight puzzle
The separations of the attached file appear different depending on which preflight viewer is used.
When you look at the separations, does the black drop shadow appear knocked out of the spot color? overprinting? single or multi color shadow? Or?
Please indicate what app and version you're using to preflight the file.
Thanks.
Acrobat DC version 2018.011.20063. Separations: CMYK + PMS 2032 C. Shadow overprints spot as black only in both photos.
Well, if you ask how it appear "visually" — in acrobat dc 2018.011.20063 with overprint preview window on it feels like it knock's out 2032 pantone. Without overprint preview window on it looks like overprinting 2032
Yeah, it appears to be a bug when generating the PDF rather than a bug in the viewer. :-(
Weird. I have the same version and the black shadow overprints whether I have output preview open or not.
Well, technically it should show like"no overprint" 'cause there is no overprint on the image
I don't think it's a bug. If you want to see it similarly with op window on and without you should go ctrl (cmd)+k —> page display
No there is no 'overprint' of the shadow. It is 2018. The shadow is a transparency effect that allows the shadow to print over the background color. When I said it overprints the spot color, it does. But not because of an overprint setting but because of transparency.
The area in pink is the transparent region which is the shadow area. You can view where transparency is in a PDF with the Acrobat Flattener Preview tool.
Just for your information, it turns out that the problem was a bug in the software embedding the correct profile. If the correct profile (that the original file was created in) is embedded using Acrobat - then the file separates correctly.
