Overprint Mode 0 and 1
Ritchie
I have recently downloaded test patches from the Ghent Work Group and run then through our RIP to test compliance. Many of the patches have been set up with two modes of overprint OPM 0 and OPM 1. I have tried to find further information regarding these two set ups but haven't had much luck. Does anyone know what the differences are or can point me to documentation which may help.
Re: Overprint Mode 0 and 1
OPM is documented in the PDF Reference.
Martin Bailey
You can get a good explanation by downloading the AltonaTestSuite documentation from www.eci.org
Paul Santer
Thanks for the reply Martin, and excuse my ignorance but, could you expand further on the "PDF reference" you refer to. Is this a particular document or reference data associated with the patch.
Ritchie,
OPM 1 is needed when you have an CMYK Object (defined in DeviceCMYK) overprinting another (Device)CMYK Object.
Meaning:
DeviceCMYK overprinting another DeviceCMYK and OPM = 0 will result in the color tints of the CMYK object on top.
DeviceCMYK overprinting another DeviceCMYK and OPM = 1 will result in the color tints of the CMYK object on top and the tints of the CMYK object underneath, if the topmost tint of the colorant has 0% - meaning if 0% cyan is defined, then the cyan from the object below will be used.
Also: a DeviceCMYK image can not overprint any other CMYK object.
If you need a CMYK object overprinting another CMYK object no matter how OPM is set up, the CMYK object has to be defined in DeviceN.
Again: more in detail definition can be found in the PDF Reference Manual.
Best regards,
Peter Kleinheider
Thanks guys
I have located the PDF reference document. It's a heavy read and not having any programming experience much of it I find difficult to understand. But no more than I would expect from a very complex subject.
As the GWG patches have objects set up in OPM 0 and OPM 1. I presume these are set at application level, or does the source colour space determine which overprint mode corresponds with particular files.
Ritchie,
OPM can be set for every object. OPM is not part of the color space, but of the graphic state.
Regards,
Peter Kleinheider
Peter
I understand OPM can be applied to objects within application progams such as Adobe Illustrator (i.e. fills and strokes) but I'm struggling to understand how it's possible to set up a file with either OPM 0 or OPM 1 settings. Perhaps this refers to Transparrency settings?
Ritchie,
when creating a PDF via distiller, OPM can get controlled via the distiller settings.
When you export a PDF, OPM is set by the application. There is no way to explicitly turn it on or off. The application is responsible to use OPM accordingly. You actually should not bother too much where it comes from. It is rather important to honor OPM when generating an output. Thus the Ghent Output Suite gives you a great tool to check on that,
Special care needs to be taken when going PDF->EPS->PDF since OPM might get lost this way.
Regards,
Peter Kleinheider
Thanks for that Peter
Many of the GWG swatches have ojects/images set up both in OPM 0 and OPM 1 and some of these are rendering incorrectly through our TrueFlow RIP either with honouring or not honouring the overprints, so I'm trying to understand how the swatches are created differently in order to form an opinion of certain settings I may need to adjust in order to render both OPM 0 and OPM 1 swatches correctly.
Thanks for your patience with me, it will sink in eventually.
Regards
Ritchie
Ritchie,
again, when honoring overprinting, the PDFs have to output correctly. You should not care where it comes from or how it got created.
Very often CTP workflow's change the overprint settings in one of their modules like trapping or color management.
Do you output the patches one by one or do you amalgamate them?
How do you check the result? Is there a resulting PDF to look at?
Regards,
Peter
"You should not care where it comes from or how it got created".
Peter
I know where you're coming from Peter but my brain does find it helpful if I understand as much as possilble with issues, so I can reach a suitable solution easier.
I am analysing the patches individually, by individually I mean each file, some files have 4 patches some have a lot more.
From an interpeted TrueFlow file I am able to output to Outline PDF (although this is still subject to overprint rules) and Tiff files. These "Ripped" files can be output to calibrated Epson printers for hi resolution proofing purposes or direct to plate.
I am viewing these swatches printed on our Epson 1055 Pro 6col printer, calibrated and profiled to our Roland 700 6 col litho press.
> {quote:title=Ritchie wrote:}{quote}
Excuse my ignorance, but how this help to find a suitable solution? Ether your workflow can handle those patches correctly by honoring the overprint settings or not. If not because it is not supported, you might run into issues where it is the fault of the workflow because the output was messed up.
if you create a PS and use distiller, you can control OPM by activating the "Illustrator Overpint Mode" in the Advanced-tab.
Another way where it can come from:
a text is defined in black (DeviceGray). In order to have this text overprint another CMYK element, it has to be converted to ether DeviceCMYK or Separation Black, since DeviceGray can not overprint DeviceCMYK. If the element only gets converted to CMYK and set to overprint but OPM is 0, it is still knocking out.
Besides that I do not know of any other way to directly control OPM. I would have to do some research.
Regards,
Peter
Pitstop will show and allow you to change the OPM setting. Its found in the Prepress-->Overprint tab of the Inspector dialog.
I don't know of any desktop creative apps that give direct control of OPM to the user. Many of the files out there that are used to test some of the more obscure PDF operators are hand written by developers.
Cheers,
Rob
Our workflow enables us to chose different OP settings when inputting a file, e.g. allow spot colour overprint, allow white overprints, automatic black overprints etc. So I was wondering if these individual settings may make a difference when OPM 1 or 0 is used.
So when the GWG make their swatches in both OPM's what is different in the creation process.
The problem I have is that one of the files has a swatch created in OPM 1 right next to a swatch created in OPM 0, I can get our workflow to render both swatches correctly but not using the same settings. So if I choose NOT to honour overprints then swatch 1 is OK but swatch 2 fails, then if I choose TO honour overprints swatch 1 fails but swatch 2 is OK.
I understand that in the next version of our Trueflow workflow the ability to choose OPM 1 or 0 is included as an option, so maybe this would appear to be the solution.
It sounds to me like your workflow has the option to force all OPM's to either 1 or 0 and what you probably need for the test file to pass is the option to leave the file untouched.
I find that when we process the files from the various testing organizarions, we get the best results when we turn off all of the features designed to "fix" incorrect files as the test files are usually designed to test your workflow's ability to do as it's told.
The test files are a bit opposed to what you face in real production though. Imagine if you got a file that had 2 cyan textlines on a magenta background, both were marked to overprint but somehow one had OPM 1 and the other had OPM 0. You'd probably want them both to look the same - whether they both overprinted or both knocked out and trapped, you might not know what the designer intended but at least they would look consistent. There's a good chance the designer didn't have overprint preview on so they are probably expecting it to knockout... but they did have the overprint box checked on so maybe it shoud overprint.
I'm happy to see that the newer versions of the desktop apps have the ability to turn overprint preview on... now if there was just a way to make sure it could never be turned off. :)
Cheers,
Rob Morgan
Kodak
Rob,
I really like the way you think. Sometimes you gotta play the what if game, and draw conclusions. BTW, I agree Overprint Preview should be on all the time. Then a customer couldn't send me a white object that "disappears" when printed. "What happened to that?"
Don
So, I think I can conclue then:
The default of our Workflow forces all items to OPM 0 (this is what we would generaly use when creating PS files from native applications i.e. InDesign, Quark etc. But when we use the selection "honor all overprints" this seems to be the same as using all OPM 1 set ups, therefore any items set up as OPM 0 are not honored.
I am still not understanding how a creator selects to set up an item using OPM 0 or OPM 1 in the original file, if indeed he realizes whether he is or not. Could it be the OPM 0 or 1 is dependent on which elments are overlapping other elements and dependent on colour space and transparency?
A content creator probably has no control over which OPM is used. This is usually set behind the scenes when the design program does the Print or Save As EPS/PS/PDF operation (i.e. converting from the program's native file format to PS/PDF) Or like Peter said by changing a Distiller setting.
To create a test file to test a RIP's ability to handle both, one would use a tool like PitStop or hand code some Postscript to get all of the different combinations on a single page.
I would never recommend that you +force+ all overprints to OPM = 0 - you'll end up fielding all kinds of questions about why stuff appears to be knocking out when the Overprint button is turned on in the creative application and why you changed the designer's file. OPM 0 is rarely used these days and in the rare case where you have someone complain because you changed OPM to 1 and the file doesn't look right, you can point to the file and say that the overprint button was on - why did you press it if you didn't want it to overprint.
I think it would be very rare to find a "real-life" file that has both types of overprints on the same page.
Cheers,
Rob
