Standard Finishing
Xerox4Over
Announcement
Collapse
No announcement yet.
Acceptable dot gains for sheetfed UV
Collapse
Canon
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • oldmanprinter
    replied
    Re: Acceptable dot gains for sheetfed UV
    h5. {color:#339966}If you are using flint inks you will notice dot gains, the worse in yellow, can be approx 30 over at the 50% dot, also diamond rollers are really a good. duel compound is excellent if running between convential and hybrid, inx or sun are far better inks with less dot gain, a good durometer of 25 for all ink forms will also help you. {color}
    Leave a comment:
  • dub
    replied
    One major thing to look at is your rollers too. Most commonly when you run UV inks, your rollers will swell up causing the higher than expected dot gain when ink is transfered to the blankets. Basically a chemical reaction between the UV ink and the compound of the rubber in the rollers. If the press is being used to run both UV and conventional inks, you should look at Chameleon rollers, I believe that botcher sells them. They have a special compound of rubber that resists swelling when UV inks are used. Also you will want to check the diameter of the rollers you are using.. may want to go a bit smaller as well to accomodate for the swelling.
    Good luck,
    Dub
    Leave a comment:
  • Gerhard
    replied
    Dot Gain cannot be avoided but handled. It is related to many things from ink to paper. Also you need using the right blankets. Also the running speed is important. Maybe your printer was scared and run it too slow. The easiest way is to make a special profile for your UV ink but remember, the moment you change the ink, the blanket or the paper you might need doing it again.
    Regards,
    Gerhard
    Leave a comment:
  • janezl
    replied
    UV ink dot gain is very dependent of ink itself. I had experience, where Arets graphics/Belgium ink was showing very high TVI, while UV ink from Sun Chemical was less than 5% away from ISO values.
    Printing blanket might have impact as well...
    Regards, Janez
    Leave a comment:
  • rich apollo
    replied
    Yeah, it may be as simple as running a higher tack ink set. Downside of that is that you increase the chances for picking.
    You have to change the blankets to run Hybrid/UV, so you might look at the differences in the surface and compressibility of your blankets.
    rich
    Leave a comment:
  • G_Town
    replied
    Well that's kind of what I thought as at a previous employer we ran UV all the time and I don't recall any issues with printing too full.
    That I don't know, I do know we would adjust tack at my previous job, I'll need to find that out.
    Yes and yes.
    We get MONSTER dot gains compared to conventional inks and I'm trying to pinpoint why that is.
    Leave a comment:
  • rich apollo
    replied
    I don't think that Hybrid/UV inks inherently have higher dot gains.
    Do the Hybrid/UV inks you're working with have the same tack as your conventional inks?
    Are you running the same screening? Same paper?
    rich
    Leave a comment:
  • G_Town
    started a topic Acceptable dot gains for sheetfed UV
    What are people getting for dot gains when running UV and hybrid inks?
    What are the most common reasons for excessive dot gain when running UV/hybrid.
    Why does UV have more dot gain then conventional inks?
    Finally what are the solutions when excessive dot gain is happening?
    Not a pressman just trying to see what are the causes and resolutions.
CanonKBAAvantiSmartsoft (Presswise)DuploEnfocusXerox4Over
Canon Embellishment White Paper
Collapse
Print Embellishment Goes
Straight To The Bottom Line
InfoTrends reported that interviews with more than 100 print customers demonstrated an appetite and willingness to pay premiums of 24% to 89% for special effects, over CMYK-only printing. They also indicated embellishment could apply to a significant portion of their work. Embellishment options can include hot foil stamping, spot gloss UV, embossing, debossing, letterpress, diecut shapes, lamination, duplex, triplex, gold foil, silver foil, copper foil, white foil, black foil, clear foil, etching, and laser cutting techniques. Download The Free White Paper.
CanonSmartsoft (Presswise)AvantiKBAAvantiEnfocusGraph ExpoDuploXeroxChili publish4Over
What's Going On
Collapse
There are currently 4243 users online. 54 members and 4189 guests.
Most users ever online was 10,745 at 04:03 PM on 10-10-2019.
Working...
X
