MCS
4Over
Announcement
No announcement yet.
HP Designjet 130 VS HP Designjet T120
X
  • Filter
  • Time
  • Show
Clear All
new posts
  • HP Designjet 130 VS HP Designjet T120
    Hi all, I'd like to have your advice before I buy one of those printers.
    I have done some research, and in my experience never had problems with HP, but I've read a lot of bad experiences for the designjet 130, an just a couple of bad ones for the t120.
    In this case the decision will be based on Price for the Ink, accuracy, and velocity. I will be printing digital art, as well as architectural drawings, if possible I want to use the printer for any regular letter printings (no more than 30 or 40 sheets a month)
    Will the 130 be more expensive due to the 6 cartridges? 12 with the heads?
    The color will be better compared to the 4 cartridges of the t120?
    Can somebody help me please? The prices are really good at this time for both printers.
    Thank you very very much, I really appreciate any advice regarding this matter.
  • #2
    Hi there,
    We know you are asking for advice from other users, but just wanted to let you know that you can also get advice from an HP Designjet sales representative on which printer would be best for your specific print needs, either by:
    Calling HP at 1-888-772-9897
    or
    Via:https://h30406.www3.hp.com/campaigns...s/en/index.php
    We hope this could be of some help to you!
    Comment
    • #3
      Well, HP Designjet 130 and T120 both have good overview and features. I have tried using 130 before and I encounter problems but not that critical. It doesn't mean that it is an awful equipment. I haven't tried T120 yet so I can't tell if it is good or not.
      CustomClothing.Co.Nz
      Comment
      • #4
        HP 130 was the first "desktop" wide format printer on the market. It had several problems that don't seem to have been fixed in later versions of it. The most significant is paper feed. Unless you purchase the NR model at a hugely higher price, you can't use rolls of media unless you are handy with carpentry and can make up a roll holder (as I did). This accepts roll media but the only time you have a problem will be when you roll back the media. Its not easy spinning a roll of canvas fast enough to keep tension on it!
        The sheet feeder for some reason hardly ever picks up the last sheet in the tray. and if you don't use it for a week or so and the seasons change (Summer comes) you'll find nice little drops of ink all over the picture you printed. Usually at the very end of the page! The biggest problem I had was the ink is always in a constant state of readiness to return to its liquid stage. Other Dye in printers (Epson for one) resist ink dissolving but not this beauty. I've had three of them. They are extremely economical on ink, cheap to buy. As you unpack it you'll see why. They are primarily plastic. Everything is plastic. BUT... If you want a 600mm (24") colour photo printer, (they are useless at black and white photos) you won't find one cheaper than this. Be sure to coat the prints with one of the paper maker's photo cote products and you'll get very nice colour photos from it. Forget forever any notion you may have of printing on canvas with a DJ130 unless you have access to a spray paint booth to coat it with lacquer bec ause anything else will give you a green print inside of a few weeks. My suggestion? Either a Canon or Epson pigment printer. If you're in Australia I can point you to a 24" canon for under $1000 and they work OK with after market inks.
        AJ
        Comment
        • #5
          can i use the HP Designjet T790 ePrinter series and the Designjet T520 36 in e printer for design jobs that include a lot of text?
          Comment
          • #6
            I haven't any in depth knowledge of these printers but I know HP printers in general are almost always more economical with ink than any other brand. I suspect this is because of their unique print head system and don't need to flush the heads every time you start a job.
            Comment
            • #7
              "HP printers in general are almost always more economical with ink than any other brand" that is true! This is the reason why most people who are into printing business opt to use HP printers.
              Comment
              Standard FinishingUltimate Smartsoft (Presswise)4Over
              Enfocus
              What's Going On
              There are currently 2964 users online. 52 members and 2912 guests.
              Most users ever online was 5,872 at 11:39 AM on 09-30-2016.
              Working...
              X
