Techorans cut out
Paperboy
Hi everyone I run a 5 col sm52 cpc and in the mornings on start up the techno rand cuts out at random moments any ideas ?
Please identify why type of Technotran do you have ? if you take some PIC from ID from
the plate of Technotran for help you, in the troubleshooting
Let me know, sincerely
Blessing
[email protected]
Hydrostar compact alpha d
Hi sir:
The 1 steps: is test the Power supply Low voltage undervoltage 24V, cause can be control voltage too low 19V, Check the power supply vs the schematic diagrams from your TechnoTran HydroSTAR Compact Alpha.d.
and Repair.
2) Look for loose connection, corroded, or broken lines, or connector dirty, or faulty, clean very well and fix it.
Blessing
[email protected]
Thanks for reply I will look into this Monday - this problem causes the press to freeze - also when all up and running somtimes I have to re boot because the duct roller will not spin ? Yesterday I came in and could move the tray in the feeder up or down ?
ok, test the steps with the Voltage sir
and Repair.
Blessing
[email protected]
