Add Objects. Any option for perforated lines?
CruzinCooler
Add Objects has options to add lines but I see no option for perforated lines. Is it an option or part of another action? Thanks. I’ve been adding art files for the perf line.
Select the line and change it's style to a dashed line in inspector, or edit the action to do the same.
Yes but I want to use that line at various sizes and positions and don't want to have to edit it all the time. I was looking to see if that action "Add Objects" can be added in the future with a simple add dashes to it. Or if it's available as an action that I did not see. Thanks for the response.
Ok I figured it out. Used the line tool first to create the line, stroke and color. Than I created an action using the Add Copied Graphics. Than into the Repeat section and set all my settings so it will accommodate my size accordingly based on Trim. A little bit of work to figure out but now I got it to add a 3/8" perf on any size doc without specifying size.
