477 gsm digital printer
ErnieLail
Have you guys ever heard of a printer that will print 24pt (477 gsm)? I recently purchased a product at the store that looks like it was printed full color laser. I didnt think there was anything out there that could do something this thick.
I believe the Xante Illumina is spec'd at 26pt board but it's the only one I know of, the second thickest from my understanding is the Indigo which is supposed to run 18pt
Look at Convertible Solutions, they have a product called Double Thick 24pt cards. It's actually two sheets with a co-adhesive, pretty neat.
Yes the Xante Production Press will - Also what about MGI? I know you can print plastic cards with them.
The Xante and Intec are re-branded Okidata printers.
You may be able to feed and print the heavy weight sheets, but it will come at a high cost. The imaging drums will take a beating and succumb well before their rated life. Registration at the tail of the sheet will also be an issue. Don't purchase without testing thoroughly and calculating your true cost per impression.
Dave
Check out Convertible Solutions, they have a product called Double Thick. It allows you to achieve the thickness on a "normal" cover stock.
