Greetings folks,
Here is a PostScript file that shows you a CMYK build
and then
shows you all of the possible CMYK builds around the specified values.
We use it to tweak colors on the iGEN.
--- IF NOTHING ELSE ... IT IS SORT OF FUN ---
Open the PostScript file with "Text Edit" (or similar)
You set the values in the "User Modification" area
for C - M - Y - K
"Save" the file
then run it through Distiller
and view the produced PDF.
Attn:
a value of 1.00 = 100%
a value of 0.45 = 45%
MSD
and then
for C - M - Y - K
"Save" the file
Attn:
MSD
