Hey PrintPlanet!
I have an Illustrator (CS5 - v15.00) doc that has many layers; this will be saved as a layered .pdf file (Acrobat 9 Pro - v9.4.5).
2 things I need to figure out...
1) how can I make it so that when the layered .pdf is opened in Acrobat that it comes up with a layer locked (that cannot be unlocked in Acrobat) so it is uneditable? and
2) I also need for the same .pdf to open up in Acrobat with one layer’s view turned off, while still having that layer in the .pdf so it can be turned on and viewed when needed.
I've been checking around in both apps, and I am not having any luck with finding where to edit these param’s. Has anyone out there on the PrintPlanet ever had to figure these things out? Thanks in advance if you can help me... I appreciate any ideas I can try.
Peace to the PrintPlanet!
_mjnc
_mjnc
