Re: Adding a Printer in Prinergy
Hi there, here goes;
Point the Oris rip to look for files in a folder on its hard drive. Name the folder and share it out.
On the Prinergy side, create a process plan with a output of 720 dpi TIFF CT (256 levels). Actually, just use one of the old Epson 9000 default process plans. Still good.
In the sub-menu output of the process plan, type in the UNC path \\NAMEOFCOMPUTERTHATHASORISRIP\SHAREDFOLDER.
If Prinergy barfs out a message saying it can't find the folder, then you may need to add the input volume. Go to the Prinergy administrator, under tools->configure system->input volumes, add the Oris server. Then Prinergy should "see" the server and away you go.
Let me know if those instructions help you out. If it's too confusing without screencaps, then I will try to post up the procedure on my blog.]
cheers ,DJ
